Symantec AntiVirus Enterprise Edition on CallManager Server
Answered Question
Feb 13th, 2007
Can I install Symantec AntiVirus Enterprise Edition on CallManager Server 4.2(3) ???
Mohamed
Correct Answer by Brandon Buffin about 9 years 7 months ago
Mohamed,
I would not recommend installing the full Enterprise Edition suite as it will not be TAC supported.
It looks like from Symantec's website that Antivirus Corporate Edition is one component of Antivirus Enterprise Edition. See the following link. It's possible that the Enterprise Edition would allow you to install only the Antivirus Corporate Edition component. I believe this would be acceptable.
http://www.symantec.com/enterprise/products/overview.jsp?pcid=1008&pvid=804_1
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Brandon Buffin Tue, 02/13/2007 - 15:03
Mohamed,
Symantec AntiVirus Corporate Edition is supported, but not Enterprise Edition. This is most likely because the Enterprise Edition is a suite of products that includes functionality that is not applicable to the Callmanager environment. Take a look at the following link.
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/prod_bulletin0900aecd800f8572.html
Hope this helps. If so, please rate the post.
Brandon
moabdallah Tue, 02/13/2007 - 20:21
Hi Brandon,
Thanks for your reply
My cusomter has only the Symantec Anivirus Enterprise Edition
Do you think it may casue any problem if I install on Cisco CallManager Server ?
Mohamed
Correct Answer
Brandon Buffin Wed, 02/14/2007 - 05:15
Mohamed,
Hope this helps.
Brandon
mloraditch Wed, 02/14/2007 - 10:54
Enterprise edition merely indicates a bundled suite of licenses for AV Corp, AV for SMTP/Exchange and Web Filtering. You would be fine installing just the AV Corp client on your CM. The other products on enterprise are separate installations and cds that you would never install on a cm anyway.
