ASA5520 - configure log
Answered Question
Feb 13th, 2007
I have configure the logging for my asa5520 v7.2(1)
but, it is no traffic out of the box.
logging enable
logging standby
logging buffered debugging
logging asdm informational
logging facility 23
logging host outside-admin 10.1.1.1
but, on my unix machine I can not see the traffic. So, on the switch I set the monitor to see the port ouside-admin, and it is confirmed there is no traffic to 10.1.1.1.
I can see the log by show logging on asa5520.
Any comments will be appreciated
Thanks in advance
Correct Answer by vitripat about 9 years 7 months ago
We would need to work on the syslog server. ASA is configured fine now and sending the logs to the server. Need to verify the configuration of the server.
Let me know if your main issue has been resolved.
Please try following command-
logging trap debug
Now you should see logs at 10.1.1.1.
Overall Rating: 5 (2 ratings)
Correct Answer
vitripat Tue, 02/13/2007 - 18:16
logging trap debug
julxu Tue, 02/13/2007 - 19:00
Great thanks for the quick reply.
yes, after put the command, I can see the syslog has been send to my unix machine,. But, I can still not see in logfile.
on the ASA I have used facility 23, and on unix box local7.
I have also tried reset facility to default 20, and I still can not see on local4 syslog file.
Many Regards
Correct Answer
vitripat Tue, 02/13/2007 - 19:37
julxu Tue, 02/13/2007 - 19:55
yes, the main issure has been solved. the problem is the server has a firewall to stop the syslog.
Thousands thanks
