hi everybody
Feb 13th, 2007
i am using 2 mbps vpn for connecting to remote site and internet. with this link we are observing packet packet drop for remote location. so we take one more vpn link of 2 mbps. I want to use this link to load balance the traffic through both the links. Can any body tell me how can i achieve this.
regards
Yamin
spremkumar Tue, 02/13/2007 - 23:14
Hi Yamin
Are you using IPSEC tunnels to have VPN connectivity between your locations ?
If yes is this VPN terminated on your router or on your firewall if any ?
regds
mheusinger Wed, 02/14/2007 - 00:27
Hi Yamin,
what Edwin is kindly asking for: can you give the relevant information about your topology and involved devices. In addition inforations like routing protocols (if present) would be helpful. Otherwise it is hard to figure out what can be done for you.
Regards, Martin
yaminqureshi Wed, 02/14/2007 - 02:05
we have 2811 router connecting to 3700 series router and we want to load balance the traffic on 2811 router for incoming and outgoing traffic and we are using OSPF as routing protocol.
regards
Yamin
yaminqureshi Wed, 02/14/2007 - 02:00
Yes we are using IPSEC tunnel for VPN connectivity between our locations and VPN is terminated on our router.
regards
Yamin
