Aspect ICM 7.0 Integration
Feb 14th, 2007
I am attempting to get my Aspect hooked up with ICM but I'm having a few problem understanding the Call Variable mapping requirements.
The call is delivered via a TR ok but the datalink request back to the PG is not being understood (I see an error - Dialed number RTE is not configured) I think this is to do with the Peripheral Variable Config parameters but can't be 100%.
The PIM is ok (active) and I can see agent state changes on the Aspect via the ICM.
RCD table shows what I would expect to see eg label is the TR route number and Target Label is the final CCT.
The Aspect is running a 2 step CCT at the moment but this can be moved to a 3 if you recomend that.
Can anyone help?
bullett Tue, 02/20/2007 - 07:54
Thanks, but I already have that document and it's not clear on what it means in a number of cases.
Alex
bullett Tue, 12/16/2008 - 08:45
I believe we did resolve this. From memory there were a number of issues in getting ICM/Aspect working together.
One was ensuring that you used a fully resolved machine name (eg machine name and domain) to define the aspect connection.
The second which I think is the one above was caused by the customer trying to run multiple ICM connections to a single Aspect without properly defining the resources on the Aspect side. Eg multiple ICM connections require a full set of dedicated links/agents/skills/CCT's etc you can't share these resources as if you do the Aspect does not know which link to use to communicate back to ICM.
Hope this helps.
