Unable to configure Ciscoview router
Feb 14th, 2007
I can't configure a router which is shown on ciscoview - I can only monitor the device.I'm with admin rights.
Thanks in advance!
Overall Rating: 1 (1 ratings)
frankzehrer Wed, 02/14/2007 - 03:06
Hi Nikolay,
since my crystal ball is in repair i have to ask you:
What version of CiscoView or LMS are you running.
What device type and IOS do you have.
Is the SNMP write string correct?
What Javer version do you use on the PC you are woring with CV?
Best regards,
Frank
nkirtchev Wed, 02/14/2007 - 06:04
Hi Frank:)
The version of CV is 6.1.2,device is router 2611, IOS 12.3(1a)
I'm not so sure about the string - but when I start the device center and from "tools" ->"management station to device" the report for snmpv1 and snmpv2 is OK.
The Javer(Java?:))is 2.2 -the recomended.
Thank you for the help:)
