ospf
Feb 14th, 2007
Hi all, I am reading my cisco ccna book, it mentions ASBR routers, how do you define an as in ospf ?
royalblues Wed, 02/14/2007 - 02:17
Hi Carl,
The as# is appended to the router OSPF comamnd
Eg. router ospf 100
Regarding ASBR - These are the routers which pass on external routing information into the OSPF domain.
Eg. External routing information can be passed onto OSPF domain through redistribution
HTH, rate if it does
Narayan
carl_townshend Wed, 02/14/2007 - 02:28
do you mean redistributing eigrp into ospf for example, and i believe the 100 is just a process number only relevant to the router not an as number
royalblues Wed, 02/14/2007 - 02:59
yes you are correct.
The number you mention is just a process ID (and not excatly an AS) which acts as an identifier if you have multiple ospf process running on a single router.
The entire OSPF toplogy is considered to be under a common AS and hence the router which originates information about outside AS (say through rredistibution) is called as ASBR
Narayan
