Question about Config Synchronisation on CSS
Feb 14th, 2007
Hi All,
i had a great Configuration on 2 CSS 11503 and want to synchronize the configurations.
Now the customer asks which risk will be there.
Does anybody now problems with that Feature ??
Thx in advance for your support
Gilles Dufour Wed, 02/14/2007 - 02:33
Joerg,
I would suggest to take the release notes of the customer software version and verify if there was any bugs opened with the config synch command.
I know there was a few of them in the past.
Gilles.
joerg.micheel Fri, 02/16/2007 - 02:21
Hi Gilles,
thx for your help.
Do you know that the config synch feature is only supported without having redundant VIP?s ?
Is this in planning to support with VIP?s ?
Bye joerg
Gilles Dufour Fri, 02/16/2007 - 02:48
config synch works with redundant-vip.
Just be aware that there are 2 type of redundancy available on the CSS
- box-to-box
- vip/interface redundancy
Each solution comes with its own synch script/command.
Make sure to use the appropriate one for your setup.
Gilles.
joerg.micheel Sun, 02/18/2007 - 23:35
Hi Gilles,
thx for your help. Now it works fine, whne i use the right command.
bye joerg
