Router 2621 strange situation
Feb 14th, 2007
Hello! I have cisco 2621 with IOS
c2600-i-mz.122-3b
with 32Mb mamory and 8 Mb flash.
The router have 2 fastethernet interfaces that are connected to 2 lans. when i try to transfer file from one LAN to another i get speed transfer max 100Kbps.I dont have any QoS or traffic policy, i dont have any extra routing ....
After show process and show memory i see that I have a lot of free memory and
CPU utilization for five seconds: 7%/7%; one minute: 5%; five minutes: 6%
Any tips!
THANKS!
BEST REGARDS
Enes
royalblues Wed, 02/14/2007 - 02:19
Check your desktops are operating at full duplex are not.
Most of the time i have seen that these interface parameters are not negotiated properly and results in poor performance.
HTH, rate if it does
Narayan
glen.grant Wed, 02/14/2007 - 03:21
Check make sure the router ports and the ports on your lan switch are hardcoded on both sides . Look for errors on either side to see if this is causing a problem . Some older router cards do not have autonegotiate capability so both sides including the lan switch side must be hardcoded , you can't leave the switch as auto .
fisko Wed, 02/14/2007 - 05:12
HM! There is no any CRC errors on interface so i supose that is not speed router vs speed switch.....catalyst 2950
