ACE Cold Standby
Feb 14th, 2007
I've got an question about ACE modules in HA, when one of the switch is reloaded a couple of the ACE contexts come up in cold standby. I've check the config in the contexts to confirm that they match and the same ft interface is used by all contexts. When I do a switchover them come up in hot standby, has anybody seen this before ? I've looked at a couple of bugs in the standby area but can't see one to match.
After reload.
FT Group : 3
Configured Status : in-service
Maintenance mode : MAINT_MODE_OFF
My State : FSM_FT_STATE_ACTIVE
Peer State : FSM_FT_STATE_STANDBY_COLD
Peer Id : 1
No. of Contexts : 1
After switchover.
FT Group : 3
My Config Priority : 100
My Net Priority : 100
My Preempt : Disabled
Peer State : FSM_FT_STATE_STANDBY_HOT
Peer Config Priority : 200
Peer Net Priority : 200
Peer Preempt : Enabled
Peer Id : 1
The software version is 3.0(0)A1(4
Overall Rating: 4 (1 ratings)
Gilles Dufour Wed, 02/14/2007 - 04:19
do you have any files like script probes or ssl certificates/keys being used in the config ?
The files are not synchronized between the 2 ACE module, so if you copy a file on the active and use it, the standby will not accept the config if you do not upload the same file first.
Also, if you copy the file on the standby after changing the config, the ACE will stop auto-synch.
if this is not the case and you can reproduce the problem, you should open a service request with the TAC so that troubleshooting can be done.
Gilles.
c.downie Wed, 02/14/2007 - 04:31
Giles, I've only a basic config on the context that's I'm faulting. No SSL certs/keys or script files but I'll double check. I've seen it a couple of times in testing so I should be able to reproduce it.
Charlie.
c.downie Fri, 02/16/2007 - 03:23
Giles,
Look's like it was the banner, it was copied from an existing running config before being copied across to the second module using copy runn start.
I suspect it must contain some special character on the first module, that didn't show up when doing a diff between the contexts.
I have a similar issue, I had been working on an ssl config and did not have the keys/certs on both modules. Now I have all of the ssl configuration removed, removed the keys/certs, and it is still stuck in FSM_FT_STATE_STANDBY_COLD
We have compared configs, and even erased the offending context configuration and reloaded standby module -- same thing.
Version 3.0(0)A1(5a)
After working with TAC , it looks like my configuration stopped synching from an probe that was configured with bad syntax. Apparently the original version of the ACE code did not care, and now it did. We found this from looking
at the output of a sh tech and looking for errors with cfgmgr. You could see the sync failing and what part of the config it was having problems with.
