ISDN BRI
Feb 14th, 2007
Dear All,
Please attachment.
I have 2 location connected to via Lease Line and backup via isdn.
When I test isdn line it works fine , but when I give show isdn status bri0 on location 2, it shows me only channel BRI0:1 and not BRI0:2.
So what should I do to know weather my BRI0:2 is wroking or not.
Jitesh
spremkumar Wed, 02/14/2007 - 04:49
Hi Jitesh
Can you remove the command ppp multilink links minimum 2 under the dialer interface and check ?
You can also make use of show isdn active command to check the active channels connected..
regds
