Cisco Works + Cisco VPN 3000 Compliance Check
Feb 14th, 2007
Im trying to do a compliance test for our VPN 3000 concentrators in Cisco works but I can not get the CLI command right. I know that the VPN 3000 doesn't run proper IOS, so what commands can I use? I've read the User guide for RME, but I can't find what I'm looking for.
help is much apreciated
BR,
kristian
andreas.larsen@... Wed, 02/14/2007 - 06:48
What compliance test do you mean ? If you want to import configuration to RME from a Vpn3000 you add it thru device manager and instead of filling out enable password etc (or tacacs+ username) you add the credentials in the HTTP section.
kristiansedstrom Wed, 02/14/2007 - 07:14
The configurations from my vpn 3000 boxes are already imported. I'm trying to check that the configs follow my template. When you have a Baseline Template you can choose "Compliance Check" and select the boxes you'd like to check (without deploy). As a result, a nice report should be generated.
