02-14-2007 07:26 AM - edited 02-21-2020 02:52 PM
Hi all,
I have configured my pix 515e 7.0(4) as a VPN concentrator.
The connection works, but the VPN stays up for a period that can be
from 20 minutes to about 2 hours.
The pix interfaces are connected to a L3 switch Alcatel 7700,
802.1q vlan are configured because I have 3 ETHon the PIX and
wanted to use vlan to gain some more zone with my physical Int.
I paste the interface configuration on the PIX
interface Ethernet0
no nameif
no security-level
no ip address
interface Ethernet0.4094
vlan 4094
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.248 standby x.x.x.x
interface Ethernet1
speed 100
duplex full
no nameif
no security-level
no ip address
interface Ethernet1.100
vlan 100
nameif inside
security-level 100
ip address x.x.x.x 255.255.255.0 standby x.x.x.x
interface Ethernet2
description STATE Failover Interface
As the VPN disconnect (reason 433 on VPN client 4.8.01.0300 )
on the pix log there is
Feb 14 2007 15:51:19: %PIX-3-713123: Group = cup_terminal, Username = TESTUSER, IP = X.X.X.X , IKE lost contact with remote peer, deleting connection (keepalive type: DPD)
Feb 14 2007 15:51:19: %PIX-4-113019: Group = cup_terminal, Username = TESTUSER, IP = X.X.X.X , Session disconnected. Session Type: IPSecOverTCP, Duration: 0h:21m:25s, Bytes xmt: 0, Bytes rcv: 0, Reason: Lost Service
Looking for a reason , what I found is:
Interface Ethernet1 "", is up, line protocol is up
Hardware is i82559, BW 100 Mbps
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
Available but not configured via nameif
MAC address 0017.9514.8a24, MTU not set
IP address unassigned
291476 packets input, 56333857 bytes, 0 no buffer
Received 230045 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
195560 L2 decode drops
67039 packets output, 7648949 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/6)
output queue (curr/max blocks): hardware (0/6) software (0/1)
L2 decode drops are very high on on both of the interface.
I couldn't find much about this counter, just this explanation:
L2 decode drops
The number of packets dropped because the name is not configured (nameif command)
or a frame with an invalid VLAN id is received.
Is it normal such a behaviour as I configure subinterface ?
Could it be a 802.1q problem with the switch ?
Before I change my configuration erasing subinterface, what else could I try ?
Any suggestion will be appreciated.
Marco.
02-14-2007 07:33 AM
Hi Marco,
You might want to look into things like... vpn client idle timeout, maximum connection time, increasing the keepalive interval etc.
HTH,
Kamal
02-15-2007 09:01 AM
Hi Kamal,
thanks for your interest.
Idle timeout and maximum connection time are
quite high, connection falls much before.
keepalive interval...what value could I try ?
I add the the configuration on the PIX, together with some debug both on the pix
and the client side.
On the client side I put a ping through the tunnel, the request timeout on the clinet happened while on the pix side
debug crypto isakmp 7
showed that it wasn't able to reach the peer.
I was trying to exclude internet problem,
what else can I do to troubleshoot ?
Marco.
02-15-2007 11:36 AM
I think default keepalive interval is 300 seconds for RA. But I'm not sure that necessarily explains why your dpd messages are not being replied to.
