Problems redirecting clients to the cisco 1.1.1.1 landing page
Feb 14th, 2007
I need some advise on a very unusual problem.
We have a cisco wireless lan controller which has a dsl connection out to the internet.
The way it works is that a client types in the url www.bbc.co.uk. The wireless controller will validate the authencity of the web address before presenting the client with a landing page for authentication which is 1.1.1.1.
If the web site is not valid, a page cannot be displayed error is returned. If it is valid , client authenticates on the 1.1.1.1 page and is allowed access.
This is the way it has always worked. But there is a new problem now where the wireless lan controller is not presenting us with the landing page , we are having to type it in the url manually which is an inconvinience for most end users.
Funny enough if you input the management address of the dsl router, you are immediately presented with the landing page.
Any ideas, guys and girls.
Stephen Rodriguez Fri, 02/16/2007 - 20:58
what code is your WLC running? There is a change made in 4.0.179.11, that allows the client to directly query the DNS instead of the management interface proxing it.
One way to see if you're having a DNS issue is to browse to an IP address, so there is no need for DNS. If you get the redirect page correctly, then I would start tracing a client to see if DNS is getting blocked somewhere.
We have the same problem and are running 4.0.179.11. If DNS fails, you get no landing page...actually we can't even get DNS. TAC had us put a Pre-Auth ACL in to allow DNS. This works as the firewall now sees the DNS request from the client, but the response never makes it back to the client because the firewall is ARP'ing for the client and never gets a response.
At this point TAC still has no solution. If we remove Web-Auth all is fine.
charlesdf22 Mon, 02/26/2007 - 20:33
We have the same issue with a Linux based firewall. We have been promised a solution for several months now, however.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
