Data T1 configuration with controller command
Feb 14th, 2007
Has anybody configured a data T1 by using controller t1 command? What I have seen is T1 Dsu kind of wic which doesn't use controller command, instead using service-module command, which there is no show controller for that. The reason I am asking this is that one of our customer said that they have slip on data T1. Before I asked them which t1 module they use I would like to know from you guys. Thanks
timmektrakarn Wed, 02/14/2007 - 11:54
You use the channel-group sub command on the controller t1 for that kind of T1 module. If you're experiencing slips you should check the clocking. Most of the time it should be set to line.
