CME with CUE
Feb 14th, 2007
Is there a way to use mulitple Cisco Unity Express cards(CUE)(mulitple CUEs each on a different router within the same network) with one instance of CallManager Express (CME). One of the CUEs is on the same router as the CME.
The remote sites have SRST running with a AIM-CUE card. The central site has CME running with a NM-CUE module. I would like to take advantage of the potential voicemail boxes on the AIM-CUE cards at the remote sites via a distributed voicemail model while maintaining the central site deployment model for call processing.
shazlett Wed, 02/14/2007 - 08:27
It appears that in order to do this the central site must be running full CallManager and not CME. Is this true???
mchandak Wed, 02/14/2007 - 13:13
AFAIK, CME with CUE is only supported on the same router.
