confusion on Cisco clean access and Cisco NAC
Feb 14th, 2007
Dear Pros,
I still confuse with the name mismatch as above. Please any one give me the correct NAC part number for both server and manager
swamy
Overall Rating: 4 (1 ratings)
dominic.bilodea... Fri, 02/16/2007 - 06:55
Cisco Clean Access and NAC are the same.
NAC is just the new naming.
You can have NAC installed in two way, Framework or Appliance mode.
I think Framework is not available anymore (I may be wrong).
If you go with the appliance, you'll need a minimum of two. 1 for the CAM (Clean Access Manager) which manages the policies and 1 for the CAS (Clean Access Server) that is the "filter" between your authentication lan and your prod network.
Dominic
