Software to try CTI Ports ?
Feb 14th, 2007
I have some problems integrating a third party unified messaging solution with a Cisco CallManager 4.1.3.
This UM Solution is using CTI ports to connect to CCM. CTI Ports are well registered but I'm unable to establish incoming and outgoing calls.
I verified everythings (partition, CSS, user association, ...) but without success.
So I'm searching to test CTI Ports without the 3rd Party UM Solution.
Something like a CTI Phone that would be able to register CTI Ports on CCM and to make/receive calls.
Does it exist ? If yes, were can I find it ?
Thanx,
Bastien.
Overall Rating: 5 (1 ratings)
BABARCHE Wed, 02/14/2007 - 09:20
Thank you for your answer !
It's a shame I did not think about that !!
:p
