Exchange 2003 SP2 Upgrade Question
Feb 14th, 2007
Have a 4.0.4 with failover. Upgrading Exchange 2003 to SP2. When we upgrade the Unity servers, do we need to upgrade in a certain order, (i.e. primary then secondary)? I can't find anything in documentation.
sopayne Wed, 02/14/2007 - 13:01
I didn't find anything specific in documentation, which indicates that there is no required order.
I'd definitely suggest that you upgrade them all during the same session, i.e. don't leave one upgraded and the others not for any regular business day.
With regards to the Unity servers, you should probably upgrade the primary first, then the secondary.
I hope this helps.
