switching
Feb 14th, 2007
Hi all, is there a rule for how many switches you can have for reach sopanning tree root ?
Overall Rating: 4 (1 ratings)
royalblues Wed, 02/14/2007 - 09:37
There is no hard and fast rule but all the spanning tree parameters are based on a diameter of 7 switches from the root
HTH, rate if it does
Narayan
carl_townshend Wed, 02/14/2007 - 12:12
what do we do if there are more than 7 bridges here ?, would we use another vlan so this then has another instance of a root ?
You can change the diameter number as part of a CLI command at the root bridge.
Switch(config)# spanning-tree vlan vlan-id root
{primary | secondary} [diameter diameter]
I would however ensure that all spanning-tree timers are adequate for the diameter you configure. (debug)
The out-of-the-box spanning tree timer defaults are based on a tree diameter of less than or equal to 7.
carl_townshend Wed, 02/14/2007 - 16:28
would this be if they were daisy chained twicw together? how about if they all plugged into 1 dist switch ?
