Simple question on configuring a router
Feb 14th, 2007
Hello everyone.
Have a question on setting up a 2610 router.
I'm studying for my CCNA and have a ways to go. I have brought in a 2610 router as well as a 1720 and am setting up a lab to play around in.
My question is this:
On the 2610, I would like to configure it so it will pick up IP address from my ISP via DHCP.
Some questions though.
1.) This router has a T1 CSU/DSU card in it. Correct me if I am wrong, but those are geared directly for a T-1 correct?
2.) If that is the case, would it be best to configure ethernet 0/0 to pick up a IP address via DHCP from my ISP (I don't have static IP's unfortunately.)
Been awhile since I have worked in a router, so I am working on getting my bearings.
just wanted to ask.
Thanks for the help.
Jason
ahmednaas Wed, 02/14/2007 - 11:19
What type of connection do you have to your ISP? Or do you want to simulate one in the lab?
thecoffeeguy Wed, 02/14/2007 - 21:05
Hello.
I have a cable modem connection with dynamic IP addressing.
Well, I have a couple of things in mind.
I have two routers: 2610 and a 1720. I also have a PIX 501.
I want to setup some type of lab with these three devices some way to get the most out of them as I can.
Does anyone have suggestions? I am open to suggestions.
Thanks.
ahmednaas Thu, 02/15/2007 - 00:36
Jason,
Your cable modem gets the dynamic IP from your ISP and I presume it has an ethernet (RJ-45) port for connection to your LAN. You can connect this to one of the routers or to the PIX.
I suggest you connect the PIX to the cable modem and then one of the routers to the PIX. Connect the 2 routers using a back-to-back serial cable to simulate a WAN connection.
To have a router interface get an ip fro dhcp:
router#config terminal
router(config)#int e0
router(config-int)#ip addr dhcp
