Cannot find Dirt Restore 1.1.2
Answered Question
Feb 14th, 2007
Hello ,
We are in the process of migrating VM to UM and Iwanted to use Dirt 1.1.2 as it has alias mapping feature on Dirt Restore.However I cannot find this version on ciscounitytools.com site.The version that is available does not give this option.
Any ideas?
Radhika
Correct Answer by MikeTomasko about 9 years 7 months ago
Version 1.1.2 add the support for remapping subscriber alaises during the restore and it still exists in the most curernt version (1.1.19). There is a checkbox in DiRT Restore 1.1.19 for "Mapping Subscriber aliases from mapping file". So why don't you use the latest DiRT Backup and DiRT Restore?
Overall Rating: 5 (1 ratings)
rnarayana Wed, 02/14/2007 - 11:18
Thanks for your reply.But in DiRT restore 1.1.2 there was an option to point to CSV file which I don't find this in older version.
Any advice.
Radhika
Correct Answer
MikeTomasko Wed, 02/14/2007 - 11:25
