Alias Command on CSS11500
Feb 14th, 2007
To make things easier for my client I want to make an alias command to run the config synch script. The format of the command is:
alias usermode alias-name "command in double quotes"
this leads to my attempt at this:
alias superuser synchronize "script play commit_redundancy "172.16.2.2 -d -s" "
Notice the imbedded quotes? The CSS did and didn't like them. I have tried the normal things like using "" to represent an inbedded quote, no luck.
Anyone been there and done this?
Thanks in advance.
Gilles Dufour Thu, 02/15/2007 - 00:41
I don't think you can have an alias using quote.
So, you have to get rid of the quote.
You could set the ip with the command
set REMOTE_IP "172.16.2.2"
save_profile
Then you could simply have an alias
alias superuser synchronize "script play commit_redundancy"
If you really need the options -d and -s, you could extract the commit_redundancy file [it's a text file] and in the function Check_Arguments replace the IF statement in order to always set -f and -d by default.
Then copy the script back to the CSS via ftp.
Gilles.
