Access-list confusion!!
Feb 14th, 2007
I have an access list sorted in a specific order, whn I input this access list to the router, it moves the last line and put it as the first line
Here's what I input to the router
access-list 92 permit 17.129.136.57
access-list 92 permit 10.23.2.35
access-list 92 permit 17.164.136.162
access-list 92 permit 17.131.203.131
access-list 92 permit 179.40.99.0 0.0.0.255
access-list 92 permit 10.24.13.25
and here's how the router sort it..
Standard IP access list 92
60 permit 10.24.13.25
10 permit 17.129.136.57
20 permit 10.23.2.35
30 permit 17.164.136.162
40 permit 17.131.203.131
50 permit 179.40.99.0, wildcard bits 0.0.0.255
That is not causing any problems to us, but I just need to understand why is that?
Thanks for your help..
vsurillo Thu, 02/15/2007 - 02:23
That's really interesting!!
I'm running IOS 12.3(7)T7 and I get the exact same result when I type in the identical list...
I experimented with some additional hosts and subnets and discovered that the router seems to want to keep the hosts listed above any networks / subnets.
Here's a quick snapshot:
70 permit 2.2.2.2
90 permit 17.129.135.57
110 permit 10.23.2.38
80 permit 2.2.1.0, wildcard bits 0.0.0.255
100 permit 10.22.8.0, wildcard bits 0.0.7.255
I'm not sure if there is a technical explanation for this, but I don't believe it is "harming" anything. As long as you pay attention to the line numbers, you'll be okay.
vrs
Richard Burts Thu, 02/15/2007 - 07:12
This has been the behavior of IOS for a very long time (I think I saw it in 10.0) and is an exception to the rule that when you add a line in an access list that the new line goes to the bottom of the list. This exception is on standard access lists and not extended access lists and it will take any new line that specifies a host (/32) match and moves it above any subnet/network match.
As far as I know it does not harm anything. But it is a bit surprising to see the different behavior.
Rick
