PIX stateful failover and external circuits
Answered Question
Feb 14th, 2007
Using a pair of PIX firewalls, OS ver 7.2, in a failover setup.
The outside interfaces of the two PIXes are connected to provider on two separate circuits.
Provider claims that in such a configuration, stateful failover does not work, and we need to hook up a switch (or a couple switches) between the pair of PIXes and the two circuits.
Somehow that doesn't ring true to me. I thought stateful failover has nothing to do with the way the outside interfaces are hooked up.
Which way is it?
Can somebody point me to a document that supports either one version or the other?
Overall Rating: 5 (1 ratings)
mrinmoy.m Mon, 02/19/2007 - 20:31
Hi Dude...
Are you running the Firewall in multiple context mode. What failover you have configured - Active/Active or Active/Standby?
In this scenario the Firewalls are getting seperate updates from diff. devices and routing of the packet will also be different. U cant have diff configuration on two firewalls operating in failover mode.
Am not sure whether you get such scenario.
mrinmoy
