3750 Bond to Ports?
Answered Question
Feb 14th, 2007
I would like to bond/team 2 ports on my 3750. This is what I current have:
interface Gigabitethernet4/0/21
description "Team Member 1"
Switchport mode access
no ip address
no mdix auto
channel-group 9 mode active
spanning-tree portfast
interface Gigabitethernet4/0/22
description "Team Member 2"
no ip address
no mdix auto
Not working tho... any help appreciated. Thanks!
Overall Rating: 5 (1 ratings)
bleucube Wed, 02/14/2007 - 11:33
Actually - I have two gig network cards in my backup server that are teamed - and looking to get two ports on the same switch teamed. Just need more bandwidth for my backup agents to use.
Etherchannel does this correct?
cisconoobie Wed, 02/14/2007 - 12:05
int g4/0/21
switchport trunk encap dot1q
switchport trunk allowed vlan xx
switchport mode trunk
Channel-protocol lacp
no spanning-tree portfast
int g4/0/22
Vlan xx is the vlan that your server is in.
bleucube Wed, 02/14/2007 - 12:11
Will give it a whirl. The main switch in on the same network as the server, so don't need a Vlan.
Curious about the addition of:
Switchport trunk encap dot1q
and turning off spanning-tree portfast
Are these recommend settings?
Those are trunk settings, for trunking vlans across switches/routers.
Not sure if the server NIC teaming process is going to work like you need.
I as understand teaming, 1 virtual IP address = 1 virtual MAc address, across 2 physical NIC connections.
AFAIK this is not a throughput enhancement. You may want to read up on the Server NIC teaming and see how they recommend setting it up.
Etherchannel is a L2 switch to L2 switch function.
bleucube Wed, 02/14/2007 - 12:56
Makes more sense to me. Ah. Yep this is just two network ports coming out out of my backup server going into 1 switch.
Doesn't sound like I can do it through etherchannel then. Thanks!
bleucube Wed, 02/14/2007 - 12:52
Added the config and could not ping the server. Changed switchport mode trunk back to switchport mode access and could ping but port still show as 1 gig.
cisconoobie Wed, 02/14/2007 - 13:21
this automatically creates a port channel group 9 for LACP
bleucube Thu, 02/15/2007 - 05:10
no good - even tho mode on is an option in the list, it does not accept it. Do I need to create the channel first?
bleucube Thu, 02/15/2007 - 11:17
Answer was:
Anyhow follow this config as it is and it should solve the issue.
Sw(config) # interface Port-channel9
Sw(config-if)#no description Brain5 Team
Sw(config-if)#no switchport trunk encapsulation dot1q
Sw(config-if)#no switchport mode access
Sw(config)# no interface Port-channel9
Sw(config)#default interface range gi 4/0/21 -22
SW(config)#interface range gigabitethernet 4/0/21-22
SW(config-if-range)#switchport mode access
SW(config-if-range)#channel-group 9 mode on
sw(config)#int port-channel 9
sw (config-if)#no ip address
sw(config-if)#speed full
sw(config-if)#duplex full
end
cisconoobie Fri, 02/23/2007 - 10:54
I try doing that on a cross-stack on 3750Gs and it does not allow me to use "switchport mode access". I have to use a trunk and it works good for LACP
dahuja Fri, 02/23/2007 - 10:58
no issues with the configuration
check with the teamed adaptors , does your nics support LACP ?
robertg1234 Fri, 02/23/2007 - 18:31
Most host/server nicteaming does not support LACP (or any other etherchannel linking protocol) except for a very few servers (the Dell 1655 comes to mind -- except it's really a Dell managed switch built into the multi-blade server). Most ppl will refer to nicteaming as a HSRP-like backup/failover setup. The NIC mfgr utility will usually show the nicteaming capabilities. This is Windows, of course.
Linux has no such problems :)
Anyway, turning off any aggregation protocol will usually work.
