WLC and H-REAP Configuration
Feb 14th, 2007
If you have 2 WLC running at HQ and 35 sites with a few AP's running H-REAP and need to add more sites with approx. 8-10 AP's at those sites is another controller needed at those sites that will have 8-10 AP's?
jamesadams_66 Wed, 02/14/2007 - 16:56
According to Cisco documentation H-REAP only supports 3 or fewer AP's per remote site.
The original limitations on REAP were just based on traffic measurements (delay, jitter, loss, MTU, etc) and not on a specific number of AP's per site. There was a "recommendation" not to exceed 3 per site...
Somewhere between REAP and H-REAP the "recommendation" became a design requirement.
Bottom line, if you go over 3 APs at a remote site, plan for a local WLC controller.
Stephen Rodriguez Fri, 02/16/2007 - 20:47
As of 4.0.206.0, we support up to 8 HREAP per site. So if you only need 8 AP's you could get away with doing HREAP, if you need more than that, you would need to get a controller for the site.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
