DST fix for LMS 2.2 overdue
Feb 14th, 2007
TAC claimed a DST fix for LMS 2.2 was supposed to be out by the first week of Feb. It's now mid-Feb and the fix is still nowhere in sight at http://www.cisco.com/cgi-bin/tablebuild.pl/cd-one-3des where the LMS 2.5.x DST fix is posted. When is it going to be released for LMS 2.2?
Overall Rating: 5 (2 ratings)
Joe Clarke Wed, 02/14/2007 - 11:43
There were some last-minute test issues that arose, and we are still working to make this a quality patch. The currently expected post date is 2/16/2007.
yjdabear Fri, 02/16/2007 - 08:40
I got the following after applying the LMS 2.2 patch:
===================- Possible Warnings/Errors Encountered -===================
WARNING: Patch 110700-01 is OBSOLETE by a newer patch.
WARNING: Patch 108827-30 is OBSOLETE by a newer patch.
ERROR: This system does not have 108993-61 installed. This patch
ERROR: is required for running CiscoWorks on Solaris 2.8
ERROR: Please install this patch.
WARNING: Patch 111085-02 is OBSOLETE by a newer patch.
WARNING: REQUIRED patches are unavailable on the system.
WARNING: 108993-61
WARNING: Product will fail without these patches or superseding patches.
WARNING: These patches must be applied before running the product.
WARNING: You may proceed with installation at this time but you must
WARNING: install the patches before running the product.
# showrev -p | grep 108993 | awk '{print $2}' | grep 108993
108993-31
108993-32
108993-52
108993-23
108993-36
108993-43
yjdabear Fri, 02/16/2007 - 08:41
Is it mandatory to have 108993-61?
Patch: 108993-31 Obsoletes: 108827-40, 108991-18, 109322-09, 109461-03, 111641-01, 109680-01, 110589-02, 111217-02, 111177-06, 111921-02, 112022-02, 110194-01, 110390-02, 111090-03, 111431-01, 110700-01, 111081-01, 111464-01, 111780-01, 111085-02, 111299-04, 111393-02, 111659-07, 112218-01, 112605-04, 108997-03, 109005-05 Requires: 113648-03, 108989-01, 116602-01, 111317-05, 108528-24, 110386-01, 111023-03, 115827-01 Incompatibles: 109079-01 Packages: SUNWcarx, SUNWcsu, SUNWcsr, SUNWcslx, SUNWcsl, SUNWhea, SUNWapppr, SUNWapppu, SUNWarc, SUNWarcx, SUNWatfsr, SUNWatfsu, SUNWcstl, SUNWcstlx, SUNWdpl, SUNWdplx, SUNWnisu, SUNWlldap, SUNWmdb, SUNWmdbx, SUNWpppd, SUNWpppdr, SUNWpppdu, SUNWpppdx
Patch: 109007-13 Obsoletes: 108875-13 Requires: 108528-01, 108989-01, 108991-02, 108993-01, 108997-01 Incompatibles: Packages: SUNWcarx, SUNWcsu, SUNWcsr, SUNWcslx, SUNWcsl, SUNWesu, SUNWhea, SUNWarc, SUNWarcx, SUNWcstl, SUNWcstlx
Patch: 108993-32 Obsoletes: 108827-40, 108991-18, 109322-09, 109461-03, 111641-01, 109680-01, 110589-02, 111217-02, 111177-06, 111921-02, 112022-02, 110194-01, 110390-02, 111090-03, 111431-01, 110700-01, 111081-01, 111464-01, 111780-01, 111085-02, 111299-04, 111393-02, 111659-07, 112218-01, 112605-04, 108997-03, 109005-05 Requires: 108528-24, 108989-01, 110386-01, 111023-03, 111317-05, 113648-03, 115827-01, 116602-01, , Incompatibles: 109079-01 Packages: SUNWcarx, SUNWcsu, SUNWcsr, SUNWcslx, SUNWcsl, SUNWcsxu, SUNWhea, SUNWapppr, SUNWapppu, SUNWarc, SUNWarcx, SUNWatfsr, SUNWatfsu, SUNWcstl, SUNWcstlx, SUNWdpl, SUNWdplx, SUNWnisu, SUNWlldap, SUNWmdb, SUNWmdbx, SUNWpppd, SUNWpppdr, SUNWpppdu, SUNWpppdx
Patch: 109007-15 Obsoletes: 108875-13 Requires: 108528-01, 108989-01, 108991-02, 108993-01, 108997-01 Incompatibles: Packages: SUNWcarx, SUNWcsu, SUNWcsr, SUNWcslx, SUNWcsl, SUNWesu, SUNWhea, SUNWarc, SUNWarcx, SUNWcstl, SUNWcstlx
Patch: 108993-52 Obsoletes: 108827-40, 108991-18, 109322-09, 109461-03, 111641-01, 109680-01, 110589-02, 111217-02, 111177-06, 111921-02, 112022-02, 110194-01, 110390-02, 111090-03, 111431-01, 110700-01, 111081-01, 111464-01, 111780-01, 111085-02, 111299-04, 111393-02, 111659-07, 112218-01, 112605-04, 108997-03, 109005-05, 110511-05 Requires: 108528-24, 108989-01, 110386-01, 111023-03, 111317-05, 113648-03, 115827-01, 116602-01, , Incompatibles: 109079-01 Packages: SUNWcarx, SUNWcsu, SUNWcsr, SUNWcslx, SUNWcsl, SUNWcsxu, SUNWhea, SUNWapppr, SUNWapppu, SUNWarc, SUNWarcx, SUNWatfsr, SUNWatfsu, SUNWcstl, SUNWcstlx, SUNWdpl, SUNWdplx, SUNWnisr, SUNWnisu, SUNWlldap, SUNWmdb, SUNWmdbx, SUNWpppd, SUNWpppdr, SUNWpppdu, SUNWpppdx
Patch: 109007-21 Obsoletes: 108875-13, 111624-05 Requires: 108528-01, 108989-01, 108991-02, 108993-01, 108997-01 Incompatibles: Packages: SUNWcarx, SUNWcsu, SUNWcsr, SUNWcslx, SUNWcsl, SUNWesu, SUNWhea, SUNWarc, SUNWarcx, SUNWcstl, SUNWcstlx
Patch: 109011-01 Obsoletes: Requires: 108991-02, 108993-01, 108528-01, 108989-01, 108997-01 Incompatibles: Packages: SUNWcsu, SUNWxcu4
Patch: 109015-01 Obsoletes: Requires: 108991-02, 108993-01, 108528-01, 108989-01, 108997-01 Incompatibles: Packages: SUNWcsu
Patch: 109017-01 Obsoletes: Requires: 108993-01, 108997-01 Incompatibles: Packages: SUNWcsu
Patch: 109021-01 Obsoletes: Requires: 108991-02, 108993-01, 108528-01, 108989-01, 108997-01 Incompatibles: Packages: SUNWcsu
(snipped)
