clear crypto ipsec sa peer [address]
Feb 14th, 2007
I inadvertenty cleared this ipsec peer and have no sas for this peer now...to recover do I delete and readd the crypto map?
Kamal Malhotra Wed, 02/14/2007 - 12:28
I assume that it is a static LAN to LAN tunnel. If it correct then clear this SA on the peer also and then initiate the traffic. Don't have t remove the crypto map.
HTH,
Kamal
dgalati000 Wed, 02/14/2007 - 12:44
thanks,,,it was a routing issue for me here at the remote NOC vs the main NOC..my peer at the main NOC was able to ping and do another clear crpto etc..and it worked. thx.
