CCIE R&S question
Feb 14th, 2007
What are the differences betwenn LACP and PAGP ? I know that LACP is a IEEE protocol but other than that they seem to be the same.
Can anybody please point me to a document that would help me to understand the differences ?
Thank you
Cristian
cristip Wed, 02/14/2007 - 16:43
Thank you I had read this when I posted the message.
Couldn't understand a some of the things explained there
LACP system priority- couldn't understand the way it is used
LACP port priority- this is OK I understand
LACP administrative key- this is not, I don't understand this
glen.grant Wed, 02/14/2007 - 14:52
They are the same , lacp is the IEEE standard and pagp is cisco proprietary etherchannel protocol . I believe the IEEE standard was even derived from the cisco's version . The only real differences are the syntaxes on the interfaces , the terminalogy is slightly different .
sundar.palaniappan Wed, 02/14/2007 - 16:25
The one big advantage LACP has over PAGP is the interoperability with the other vendor switches. PAGP, being Cisco Proprietary, cannot aggregate channels with other vendor switches.
Sundar
cristip Wed, 02/14/2007 - 16:45
the priority mechanisms above mentioned do not exist in PAGP. So that may be an important differece but as I wrote above I do not undersatand the way it works.
