02-14-2007 04:22 PM - edited 03-03-2019 03:46 PM
what can the reason if access to www is not successful. however the following works
*the site is accessible for some users but not for others.
* n/w conf is fine
*telnet,ping works for fine access
* telnet does not work for problematic access but ping,trace does fine.
02-14-2007 04:42 PM
If your internet connection is via cable/DSL then try configuring 'ip tcp adjust-mss 1400' under the LAN interface facing the clients and see if that helps.
Sundar
02-16-2007 03:28 AM
You mean telnet to www port?
Check the Proxy setting in the internet browser of those users who can't access www
