remote-access VPN on 7.2(2)
Answered Question
Feb 14th, 2007
I ran into an issue with a customer where we setup his remote-access vpn via ASDM and used the same name (eg. itvpn) for the group-policy and tunnel-group. After putting the ASA on the network we were able to connect via VPN client, however we never saw any traffic being decrypted at the client end.
I then removed all the config from the CLI related to the remote-access vpn and put it back in via the CLI (instead of ASDM). The only difference I can see between the two configs is the second one I used a different name for the group-policy (eg. itvpnpolicy) and tunnel-group(eg. itvpn). We were then able to see decrypted packets at the client end and everything worked.
Does anyone have a working configuration where they are using the same name for both the group-policy and tunnel-group? Am I nuts in thinking you can't use the same name for both? Just curious if maybe I'm missing something when comparing the two configs.
Thanks!
Brad
Correct Answer by Kamal Malhotra about 9 years 7 months ago
Hi Brad,
I have seen many setups working with the same name. So its fine. You are definitely missing something else.
Kamal
Overall Rating: 5 (1 ratings)
Correct Answer
Kamal Malhotra Wed, 02/14/2007 - 17:03
Hi Brad,
Kamal
melchib Wed, 02/14/2007 - 17:45
Ok, Thanks Kamal. I appreciate the quick response too!
Brad
