CME 4.0 and 12.4(11)T or 12.4(11)T1
Feb 14th, 2007
- Has anyone notices that after you install
and reboot to 12.4(11)T or 12.4(11)T1 that
trying to use archive tar /xtract to get the
CME 4.0 files onto the router flash no longer
works successfully? I keep getting an error
to the effect that my tar file is a directory
according to the error text. Backing down
to 12.4(9)Tx does not exhibit this. Or is
there a new change on how to load CME tar
files starting in 12.4(11)x? Thanks.
Paolo Bevilacqua Thu, 02/15/2007 - 03:25
Which router is your? That may be related to the fact directories are not supported on some platforms. Also, I find absolutely unnecessary to load all the files and built my own archive with the necessary files only.
Paolo Bevilacqua Fri, 02/23/2007 - 16:07
What a strange bug, and severity just 4 ???
However I'm 99% positive I've been extracting tarfiles with 12.4(11)T.
