Multiple instance of IP Communicator on same PC
Feb 14th, 2007
hi,
I would like to setup a voice lab, I don't have ip phone. I would like to know if it is possible to run many instance of IP COmmunicator on same PC in other to simulate many phone ???
thank in advance.
Overall Rating: 3.5 (2 ratings)
gogasca Wed, 02/14/2007 - 21:35
Afaik only 1 will run at the sametime.
Try also IP Softphone and maybe some 3rd party phones like IP Blue.
deepakmaheshwari Wed, 02/14/2007 - 22:23
I think if you can install multiple Virtual PC on either VMWARE or Microsoft Virtual PC then you can run multiple instance of IP communicator from same PC
Revert me
if you have any problem
KandyOtero Thu, 06/25/2015 - 08:20
Works for me with a Virtual Box, I installed two ip communicator, one on the virtual machina and another in the fisical machine.
Best Regards Kandy
