BGP regexp
Answered Question
Feb 14th, 2007
I need some help here as I can't point my finger to the right BGP regexp.
I have multiple upstream, according to the BGP routing table the best path to "AS5" is through upstream "B" (AS2) but I want it to be in upstream "A" (AS1). I'm planning to use local-preference so that it will propagate to all iBGP routers. From provider "A", AS5 is through the following path 1 3 4 5
I'm planning to use route-map in the interface to provider "A"
The configuration look like this;
router bgp 100
neighbor ip_address_of_provider_"A" route-map incoming in
ip as-path access-list 1 permit ^1_
ip as-path access-list 2 permit ???
route-map incoming permit 1
match as-path 1
set local-preference 100
! Here is the route-map for AS5
route-map incoming permit 2
match as-path 2
set local-preference 150
The regexp for AS5 is my problem. I don't want to put 1 3 4 5 as some AS my perform prepending. I also not sure if my route-map will work with two local-preference
Thanks in advance
Correct Answer by CSCO10892433 about 9 years 7 months ago
Hi, Medan
Please add one line to end of your route map like this
match as-path 1
This will make other routes not be filtered.
SSLIN
Overall Rating: 5 (1 ratings)
CSCO10892433 Thu, 02/15/2007 - 02:17
Hi medan
If you are going to apply the route map on link to the provider A, since all the routes advertised by A(AS1) will always have as-path attribute beginning with 1, all routes will be permited by this route map, making the policy useless.What you should do is to match the routes with as-path attribute ending with 5. So change your as-path list as follows
ip as-path access-list 1 permit _5$
and set local-preference to 150 to the routes which match the above as-path list.This should make all paths to AS 5 prefer the way through provider A.
I can't understand what's your intention on the second as-path list.
SSLIN
Danilo Dy Thu, 02/15/2007 - 02:32
Hi SSLIN,
Thank you for your reply.
Ignore the second as-path list. Its for the AS5, I put ??? because I can't figure out the regexp :)
So that means I will have the following;
router bgp 100
match as-path 1
But this affects all other routes coming from AS1. From 200k prefixes, it goes down to 80 prefixes.
Correct Answer
CSCO10892433 Thu, 02/15/2007 - 03:09
Hi, Medan
match as-path 1
SSLIN
