How make a Computer into a Bridge
Answered Question
Feb 14th, 2007
Dear Friends,
I have 3 Computers (with Windows 2000 Professional).
-PC1 have 2 LAN cards (One is connected with PC2 and otherone is connected with Cisco 2950 Switch).
-PC2 have only one LAN card which is use to connect it with PC1.
-PC3 have also one LAN card which is use to connect with the same Cisco 2950 Switch.
I want that PC2 do ping or accessible for PC3...this is what I want.
Note: PC3 pin/access to PC1 but not PC2.
PC1 ping/access both PC2 & PC3.
PC2 ping/access PC1 but not PC3.
All PCs/computers are on the same Subnet (192.168.0.5/6/7 with 255.255.255.0 and all PCs are on the same Workgroup).
PLs. solve my problem.
Shahid
Correct Answer by ahmednaas about 9 years 7 months ago
I believe so, yes.
Overall Rating: 5 (1 ratings)
ahmednaas Wed, 02/14/2007 - 23:22
On pc1, enable the routing service:
control panel -> admin tools -> services -> routing
You might need to keep pc2 on separate subnet.
(On win xp pro, you can bridge between interfaces but AFAIK not on win 2000)
shahid_raza74 Thu, 02/15/2007 - 00:28
I did as you told by enabling Routing and Remote Access Service on PC1. with same and with diff. subnet...but it is not ping/access as I want.....???
Any other solution???
PLs. help me.
Shahid
ahmednaas Thu, 02/15/2007 - 01:28
Did you put pc2 in a different subnet?
You also have to configure the default gateway correctly.
also on PC1 go to:
network -> properties and right-click on one of the NIC. Ckeck if bridging is available in the list.
shahid_raza74 Fri, 02/16/2007 - 01:59
THANKS.
I have solved my problem by Bridging links on PC2 by installing XP...as you told earlier.
Does Windoes 2003 Enterprise Server also give Bridging option as Win XP gives?
Shahid
