MLPPP over Frame Relay
Feb 15th, 2007
We just tested MLPPP over FR on two physical FR links between two sites, each link having 2 Mbps bandwidth.I want to ask about how it will work if both links are of different bandwidth , let suppose 1 link is of 64kbps and 2nd is of 512kbps so what will happen if bandwidth utilization exceeds 64kbps.
Mujeeb
dsweeny Wed, 02/21/2007 - 07:40
The load will be shared between the links on the basis of the routing protocols ocnfigured on the router or switch.
The process of equal load balancing does not work here only unequal load balancing works.
