Syslog
trombidz1
I need to send syslog to a server
which command should I use :
logging xxx.xxx.xxx.xxx
or
snmp-server enable traps
snmp-server host xxx.xxx.xxx.xxx public
cheers
dav
I believe that the fundamental question here is about the relationship between: snmp-server enable traps command and syslog server. The answer is that snmp-server enable traps will enable the router to send traps to the SNMP server. It is an entirely different function than sending to a syslog server.
Rick
Rick
5 Replies 5
ahmednaas
Level 4
Level 4
If it is a syslog server then use:
logging on
logging server-ip
logging trap informational <- security level
logging facility router5 <- must match server
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_tech_note09186a00800a7275.shtml
Ok thanks but
what is snmp-server enable traps command use for ?
Hi!
You need to first build a server and then install some syslogging software on that.(Kiwi syslog is the best and its available for free!!!)
Then you need to add this server as the syslog server in all the devices from which you want logs to be stored.
On all the devices from which you want logs, enter the following commands:
- enable
- configure terminal
- logging host a.b.c.d
- logging trap '0-7'
logging level 0 is the most severe and logging level 7 is the lowest in severity.
You can also configure services so that all your logs have a time stamp with the date and time.
Enter the following commands:
- enable
- service timestamps log datetime
For more please refer the following link -->
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a00801f0a4e.html#1031634
Download Kiwi syslog daemon from the following link-->
http://www.kiwisyslog.com/php/download.php?syslogdV8_kiwitools&v=8.0.2
Using SNMP you can monitor your devices in real time, also you can monitor various aspects of the device in realtime. You can also use SNMP to make changes in the device.
Read the following link for more -->
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008019f033.html
Hope this helps...
AbhisheK
Please rate helpful posts!!!
Rick
Rick
