IP Communicator Date & Time
Feb 15th, 2007
Does anyone knows if the IP Communicator date and time settings are following CCM(4.13) or the user PC? Also, where do I start troubleshooting if the date and time setting on the IP Communicator is not synchronized with CCM?
Hann Yong
Overall Rating: 5 (2 ratings)
Dennis Fogler Thu, 02/15/2007 - 04:33
IP Communicator uses the device pool setting from Call Manager to derives its time & date, not the PC. Check the device pool settings first.
If the device pool settings are correct, check the version of IP Communicator that you are running. If you are using v1.1 then you are probably running into known bug.
Check your Call Manager to see if it set to use the local time zone of the Call Manager. If it is the IP Communicator will display time in GMT.
Change the Call Manager date to use the 'system time zone' and this should correct the date time display issue with IP Communicator.
ivan.garrido Tue, 11/27/2007 - 12:36
Message to dfogler:
I have IP Communicator v2.1.2 and CCM5.1.2. Device pool using the CMLocal that is GMT-4,Dayligth saving Time, Santiago. In Santiago we have Summer Time now, and really the time is 3 hour back the GMT now. The IP Phone display the correct time, but the IP Communicator display time in GMT. For example the CallManager OS and IP Phone display the 17:34 and the IP Communicator display the 20:34.
Can you Help me.?
Thanks.
hannyong Tue, 11/27/2007 - 18:37
Ensure that, no firewalls or access-list are inbetween the pc and CCM. I've read somewhere, the time synchronization was using a certain port.
Hope this helps
master001 Mon, 02/11/2008 - 18:15
Hi all,
I also have this similar issue.
I have IP communicator v.2 and CCM 4.1(3). The IP phones display correct time(GMT-4),
however the soft phones dsiplay GMT time only.
I already create a new device pool for soft phones only, and set the time zhone to local time zone.
The soft phones still display GMT time, not local time(GMT-4).
Any more suggestion?
If the time synchronization was using a certain port, any details info. for it?
If your post is helpful,i will rate it.
ivan.garrido Tue, 02/12/2008 - 06:50
Hi all,
I open a TAC case for it, the past year, and now, the IP Communicator V2.1.3, released January 31st resolved the GMT-4 issue. I test it and work fine!!
Iván.
master001 Fri, 02/15/2008 - 09:00
Hi Ivan,
It looks IP communicator hits the following bug:
CSCsl72204 Bug Details
IP Communicator shows wrong time for Santiago(Chile) Time Zone
Symptom:
IPComm is displaying GMT time actually 3 hours more than the actual time in Santiago/Chile.
I will install IP Communicator V2.1.3 and let you know the results.
I appreciate your post, Ivan.
Howard
master001 Tue, 02/26/2008 - 12:43
IP Communicator V2.1.3 is working perfectly.
Thanks, Ivan.
Howard
