Cisco Pix 501 firewall
Feb 15th, 2007
I am having a problem with a Cisco Pix 501 firewall.
Iam trying to setup the inside address from 192.168.1.1 ( default ) to 10.10.0.200 and i'm receiving an error :
the ip address does not match with DHCP pool.
I use the web interface and the Hyper terminal telnet .
I would appreciate if you can help me a.s.a.p.
Thank you
Overall Rating: 3 (1 ratings)
Ok, if you are not using the 501 to act as a DHCP server then you'll need to take this feature out.
In configuration mode:
clear dhcpd
save with: write mem
Now you'll be able to change the inside interface IP address i.e.
no ip address inside 192.168.1.1
ip address inside 10.10.0.200 255.255.255.0
Again - save with: write mem
Hope this helps and please rate posts.
