Moving from CVPN3000 to ASA5500?
Feb 15th, 2007
A single "stupid" question...
If you need to migrate from CVPN3000 appliances to the ASA5500, can you use the same IPsec vpn client?
Our policy is not to use SSL, so if we have to replace the client, then there are rather a lot of laptops out there.
Richard Burts Thu, 02/15/2007 - 08:04
Nicholas
I successfully use the same (Cisco) VPN client software to access VPN3000 concentrators and ASA5500 for remote access VPN. I see no reason why you would need to change clients (perhaps unless you are using a very old version of the VPN client).
Rick
nmfoxton Mon, 02/19/2007 - 06:40
Great, we're using Client V4.8.01.0300 which is relatively recent.
Many thanks.
