Directory - Host Not Found
Feb 15th, 2007
Hi Folks,
I am setting up a simple CCME using only 7911. I have created local directory using the GUI and had it enabled.
I noticed that when i access the service>directory, i get an error " Host Not Found'
Below is an extract of the services.
caller-id name-only: enable
system message LAO Asia Pacific Breweries
web admin system name admin secret 5 $1$bF8K$WMOB99ryW/Mc1NvXYewwX.
web admin customer name apb secret 5 $1$Z5rI$lo3pq22R9bU6X7zvMUyke0
edit DN through Web: enabled.
edit TIME through web: enabled.
Log (table parameters):
max-size: 150
retain-timer: 15
create cnf-files version-stamp 7960 Feb 15 2007 20:00:25
transfer-system full-consult
auto assign 1 to 288
local directory service: enabled.
PLease let me know what step have i missed.
Thankyou in advance,
Kelvin
Overall Rating: 4 (1 ratings)
Brandon Buffin Thu, 02/15/2007 - 08:47
Kelvin,
Do you have the following commands in global configuration?
ip http server
ip http path flash:
Brandon
rtappend_2 Tue, 02/20/2007 - 04:32
Kelvin,
This could be due to a problem with your config files.
Check the config file in system:/its/ called XMLDefault7911.cnf.xml. It should have a line like:
http://10.10.10.10:80/localdirectory
Make sure this is correct and accessible as this is the host it is looking for. When you reset the phone, it should download this file and hence know the location to find the directory information. You can verify this with debug tftp event.
Also check the phone load statement for your phone type. It should look something like this:
load 7911 SCCP11.7-2-1-0S.loads
The load file should be in the root of flash: and not in a sub-folder as this can cause the phone to fail to parse the XML config file correctly and it cn then not read the directory location correctly - resulting in host not found.
Hope that helps.
