CCIE - Security - Routing question
Answered Question
Feb 15th, 2007
I am about to undergo training for CCIE - Security. I understand that we have R&S as well in the course structure.
Will this be as intensive as the R&S course.. or just the basic knowledge enough
Shyam
Correct Answer by daviddtran about 9 years 7 months ago
Here is my opinion on this:
1) yes, after jan 1st, 2007, routing protocols
will be pre-configured but you still have to
know how it works. One thing you have to keep
in mind is that when you apply security on top
of R&S, things tend to break so you really
have to understand how routing protocols work.
2) even though routing protocols are pre-configured, the lab tends to leave the
hardest thing in the R&S+Security for the
candidate(s) to figure out. This separates
the good engineer(s) who really understand
how things work and the pretenders.
3) Think of it this way, Security lab, IMHO,
is much harder than the R&S (I have never been
to R&S lab) for a simple fact that the
candidate has to deal with more equipments,
ACS, Pix/ASA, VPNc, IDS/IPS, routers, switches
than R&S folks. On top of that, they have to
be aware about the R&S part as well. As I've
said before, just because routing protocols
are pre-configured does not make it any easier.
In summary, the new lab may be more security
concentrated but if you do not have solid
R&S, IMHO, you will be wasting $1250.
Overall Rating: 5 (1 ratings)
sundar.palaniappan Thu, 02/15/2007 - 12:39
Shyam,
I don't know if you are inquiring about the Security Written or Lab exam. Either way, Cisco revised the exam contents last year for the security written/lab where it was stated there will be more more emphasis on the security technologies and minimal emphasis on R&S going forward. I believe, it's effective as of Jan 1, 2007. I personally took the old Security written (version 1.0) last week and passed it and this version will not be offered after Mar 31, 2007.
Check out the following links for new written/lab exam blueprint.
http://www.cisco.com/web/learning/le3/ccie/security/wr_exam_blueprint_v2.html
http://www.cisco.com/web/learning/le3/ccie/security/lab_exam_blueprint_v2.html
Sundar
daviddtran Fri, 02/16/2007 - 05:49
I passed the security lab last year and I can say that R&S is still an important element
in the Security lab. You don't have to be
an expert in R&S (I was not) but you need
to have solid background in R&S. Some of the
questions in the security lab regarding R&S that
I think a lot of CCIEs in R&S would have
problems understanding them.
shyamatopsource Fri, 02/16/2007 - 05:56
So after getting your feedback I can assume that before Jan 1 2007 R&S was an integral part of Security. Going forward from Jan 1 2007 R&S Syllabus in Security Lab will be largly reduced.
Some one told me that the revised CCIE Sec Lab will have the routing protocols pre configured in the Lab so that we dont have to troubleshoot the routing part as well...
Can some one confirm that to me
Shyam
Correct Answer
daviddtran Fri, 02/16/2007 - 06:07
