Not using channel 12 and 13 on WLC
Answered Question
Feb 15th, 2007
We have a WLC setup, and we dont want to let the auto RF use the channel 12 and 13, because some of the devices on our network do not support these channels.
Is there a way to do this, or do I have to change the country code to US, because I think 12 and 13 are not used there?
Thank you
Correct Answer by claeysg about 9 years 7 months ago
Hello Steven ;-)
It's explained in details in the RRM white paper
Check http://www.cisco.com/warp/public/114/rrm.html
The list of channels used by the DCA algorithm, for both channel
monitoring and assignment, can be altered in WLC code version 4.0 or
later. For example, in the U.S., by default the DCA algorithm uses only
the 11b/g channels of 1, 6, and 11. In order to add channels 4 and 8,
and remove channel 6 from this DCA list, these commands must be input in
the controller CLI:
(Cisco Controller) >config advanced 802.11b channel add 4
(Cisco Controller) >config advanced 802.11b channel add 8
(Cisco Controller) >config advanced 802.11b channel delete 6
Rdgs,
Gaetan
Overall Rating: 5 (1 ratings)
Correct Answer
claeysg Thu, 02/15/2007 - 10:04
Hello Steven ;-)
the controller CLI:
Rdgs,
Gaetan
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
