duplicate ACL in pix 525?
Feb 15th, 2007
we have a pix 525 with 4 access-lists. Inside, outside, wlan, and dmz. For some reason, there appear to be 2 ACLs with the same name, inside. The 'true' inside acl has 35 lines. The other inside acl has only 1 line. Heres the kicker, I can't get rid of it. I've tried copying and pasting in the console and keep getting 'Specified access-list does not exist at that line'. It doesn't seem to be harming anything as there are no hits to the acl but I'd like to keep things tidy.
Thanks for any help,
Mike
plwalsh Tue, 02/20/2007 - 08:48
If you use this command
'show access-l | inc elem'
you get a display of any ACLs that have been configured since the firewall was last reloaded.
If there are ACLs with the same name then perhaps a reload will get rid of the unwanted one. Dont forget to save your config first.
