02-15-2007 07:38 AM - edited 03-14-2019 08:03 PM
Hey guys --
Is it possible to terminate two analog lines into one FXO port? If so, is there any extra configuration needed on the gateway?
Let me know.
Thanks.
02-15-2007 07:45 AM
I haven't tried it, but I suppose you could use a splitter to accomplish this. Obviously, with only one port, only one line could be active at a time.
Brandon
02-15-2007 07:55 AM
So the answer is no, we need both lines active at the same time. Just to add, we will terminate four pins into the cable.
Thanks for the quick response.
02-15-2007 08:03 AM
Correct. A single FXO port can only terminate 1 connection at a time.
Brandon
02-15-2007 08:10 AM
Thank you sir.
