Call Forward
Answered Question
Feb 15th, 2007
I have 7940 with two lines:
from my phone if i click CFwall it only forward calls coming to my primary line, is it possible to do it from the phone for the other line.
Good day
Correct Answer by rob.huffman about 9 years 7 months ago
Hi Wissam,
This is a very common question all of us have asked at one point or another and currently cfwdall is only supported for Line 1 on the phone.The only method available to cfwdall Line 2 etc. is to do it from ccmadmin or the ccmuser web access page.
There is also a third party product called;
IPPhone callForwarder
This new version brings to the user the ability of defining and setting the call forwards from the IP Phone. When selecting the IP Phone callForwarder service, a menu with all available lines will appear. After selecting the line the user wishes to set the forward on, a new menu containing the forward definitions will show on screen. Only those forwarding parameters definied by the Administrator will be displayed. These parameters will show the actual forward destination. The user can then set any of these callForwards.
From this link at myvoipsource.org;
http://www.voip-tools.org/index.php?option=com_content&task=view&id=47&Itemid=85
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Thu, 02/15/2007 - 07:56
Hi Wissam,
Hope this helps!
Rob
twissam Thu, 02/15/2007 - 12:29
hehe
it is funny, in the link you used voip-tools, but the right one is the one you wrote myvoicesource.org
Good day
nicolas Fri, 02/16/2007 - 08:36
Other solution in using CCMUser page
http://x.x.x.x/ccmuser
From the ccmuser page it's possible to do a CallFwd to the second line ;-)
Christophe
