ip sla - https probe
Feb 15th, 2007
Hi All
I'm trying to probe with Infovista using https and want to know the minimum release of software and feature set i need to use on the routers.
Is there any default configuration that needs to be turned on for this to work?
Thanks in advance
Matt
clarkmat Fri, 02/16/2007 - 00:35
You can configure http and then change the target port to 443. Problem is i have one that works and one that doesn't.
It is configured via SNMP but is there a limitation on the number of https probes?
I also thought perhaps that ip http server secure needed to be configured but that is not the case. Port 443 opens up when the request comes in...
