EIGRP Parallel paths vs multilink
Answered Question
EIGRP has a limit of six parralel paths. If I use multilink on 6 T1 lines will that be one path. Could I use in theory 36 T1 lines? Any advice would be appreciated. I currently have a T3 in place that averages 10MB of utilization and want to re3duce costs by getting rid of the T3.
Correct Answer by Richard Burts about 9 years 7 months ago
Stephen
In theory you should be able to have 6 multilinks with 6 T1s in each multilink bundle. There would be some cost to provide the number of T1 interfaces that you are talking about. And there would be some additional overhead on the router to manage the links within each multilink bundle and some overhead to manage the 6 paths as compared to managing a single path. But I believe that is could be done.
I wonder if a more cost effective solution might be to ask your provider about a partial rate T3. If you do not need the full rate T3 then what would they charge for 10MB (or 15MB to give yourself a bit of room to grow)?
Rick
Overall Rating: 5 (1 ratings)
Richard Burts Fri, 02/09/2007 - 09:33
Stephen
In general the more memory a router has the better off you are. But knowing how much memory is economically justified needs to know more about what kind of things you will be doing with the router.
Rick
david.lowe Thu, 02/15/2007 - 10:53
You're going to need a very high end router (including the cost of the T1 interface cards or port adapters) to pull this off. But I understand what you're getting at. One time charges are much easier to digest than monthly recurring charges.
Correct Answer
Richard Burts Thu, 02/15/2007 - 08:44
Stephen
Rick
