Disabling RIP on 6509
Feb 15th, 2007
I'm having a problem with our 6509 switch. We have had RIP enabled for a while and we'd like to disable it on this switch because we felt that it was not being used. However when RIP is disabled, after a short period of time, it appears that the 6509 loses its routes. A 'sh ip route' command shows that the route for the subnetwork I'm trying to reach is entered in, in fact it's a local interface in the 6509 so it doesn't even need a static route, it shows connected. However clients on that subnetwork can receive data, but they cannot send any data.
I have noticed that re-enabling RIP fixes this problem almost immediately. Additionally, if I leave RIP disabled, and go to a client machine, and do a 'tracert' into a PC on the network that the switch is on, communications will resume working properly.
I've had a Cisco Engineer look at the config on the switch and he says that it looks to be correct. Does anyone have any ideas what might be causing this scenario? Thanks
Richard Burts Thu, 02/15/2007 - 09:18
Dave
The symptoms that you describe sound like the PCs may be configured to do IP routing and are dependent on RIP sending them a default route. Can you confirm details of how the PCs are configured?
Rick
Dave Agro Thu, 02/15/2007 - 09:27
Here is a copy of the config. It looks a lot more confusing than it really is. Basically we're having problems with remote users which are on VLan2, or 10.1.2.x adresses.
version 12.0
no service pad
service timestamps log datetime
hostname msm15
boot system flash bootflash:c6msfc-ds-mz.120-7.XE1
enable secret 5
clock timezone CST -6
clock summer-time CDT recurring
clock calendar-valid
ip subnet-zero
ip cef
ip name-server 10.1.1.6
ip name-server 10.1.1.9
interface Vlan1
no ip address
no ip directed-broadcast
ip policy route-map RM_VLAN1
shutdown
interface Vlan2
ip address 10.1.2.5 255.255.255.0
interface Vlan11
ip address 10.1.1.5 255.255.255.0
ip policy route-map RM_VLAN11
interface Vlan19
ip address 10.1.19.5 255.255.255.0
ip helper-address 10.1.1.9
ip policy route-map RM_VLAN19
interface Vlan21
ip address 10.1.21.5 255.255.255.0
interface Vlan22
ip address 10.1.22.5 255.255.255.0
interface Vlan23
ip address 10.1.23.5 255.255.255.0
interface Vlan24
ip address 10.1.24.5 255.255.255.0
interface Vlan25
ip address 10.1.25.5 255.255.255.0
interface Vlan26
ip address 10.1.26.5 255.255.255.0
interface Vlan27
ip address 10.1.27.5 255.255.255.0
interface Vlan40
ip address 10.1.40.5 255.255.255.0
ip policy route-map RM_VLAN40
interface Vlan41
ip address 10.1.41.5 255.255.255.0
interface Vlan42
ip address 10.1.42.5 255.255.255.0
interface Vlan43
ip address 10.1.43.5 255.255.255.0
interface Vlan44
ip address 10.1.44.5 255.255.255.0
interface Vlan45
ip address 10.1.45.5 255.255.255.0
interface Vlan46
ip address 10.1.46.5 255.255.255.0
interface Vlan47
ip address 10.1.47.5 255.255.255.0
router rip
network 10.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.250
ip route 10.4.1.0 255.255.255.0 10.1.1.31
ip route 10.9.0.0 255.255.0.0 10.1.1.31
ip route 10.10.1.0 255.255.255.0 10.1.1.1
ip route 10.11.0.0 255.255.0.0 10.1.1.31
ip route 10.12.1.0 255.255.255.0 10.1.1.31
ip route 10.16.1.0 255.255.255.0 10.1.1.31
ip route 10.17.0.0 255.255.0.0 10.1.1.31
ip route 10.99.1.0 255.255.255.0 10.1.1.100
ip route 10.99.2.0 255.255.255.0 10.1.40.90
ip route 10.99.3.0 255.255.255.0 10.1.1.31
ip route 10.99.4.0 255.255.255.0 10.1.40.90
ip route 10.100.0.0 255.255.0.0 10.1.1.31
no ip http server
logging trap debugging
logging 10.1.19.114
access-list 111 permit ip 10.1.1.0 0.0.0.255 any
access-list 119 permit ip 10.1.19.0 0.0.0.255 any
access-list 140 permit ip 10.1.40.0 0.0.0.255 any
route-map RM_VLAN40 permit 10
match ip address 140
set ip default next-hop 10.1.1.1
route-map RM_VLAN11 permit 10
match ip address 111
route-map RM_VLAN19 permit 10
match ip address 119
Dave Agro Thu, 02/15/2007 - 09:29
Rick,
I guess I could see that, however we aren't on any special configuration. Normal Windows domain, using this switch/router as the default gateway.
-Dave
Richard Burts Thu, 02/15/2007 - 09:51
Dave
I have looked through the config that you posted and nothing stands out as a potential issue. I continue to feel that this is more likely an issue with something on the PC than it is an issue on the 6509.
I went back and read again your original post. Do I understand correctly that if you turn off RIP, and then from a PC do a tracert to another PC that things start to work again? Are the address of the PC that you tracert to in any particular subnet?
Rick
