bundle of etherchanels
Jon Marshall Thu, 02/15/2007 - 10:12
Hi Ali
Do you mean can you put all 4 links into one Etherchannel bundle ?
As far as i can see yes you should be able to. An etherchannel will form if all the ports have the same speed capabilities so if they are all gigabit capable i would think it would work.
You might not want to do this though as etherchannel load-balances across its links. 3 of your links are gigabit but the other one is 300Mbps.
How are you restricting the traffic on the 4th link to be 300Mbps ?
Jon
Jon Marshall Fri, 02/16/2007 - 07:05
Hi Ali
Yes the etherchannel should form as all the switch sees are 4 gigabit connections. As long as you have checked the guidelines and restrictions and all the ports have the same capabilities i see no reason why it won't work.
Jon
mahmoodmkl Sun, 02/18/2007 - 00:55
HI Sayeed,
I didnt get what do u mean by 300M.can u explain.If u want to have etherchannel u need to have all the ports in the same switch and they should have same configurations.
Mahmood
